i have a 1990 tracker and the switch that controls variable speeds for the ac fan woul only wor if you moved it around just right now it won't work at all there are no blown fusesany info would help out as its my daily driver and its getting pretty hot on the drive from work
Good Times Bad Examples
1990-8 valve-3spd auto-Tracker
when the voltage drops to zero , with fan on and blower on , bingo the fault.
in your case (above is generic)
you have 2 failures.
so the pink/black wire will NOT be at 12vdc with fan on and this is the reason
all is dead. ( this wire must be hot)
see?
unless the A/C lamp is not glowing then the fuse could be bad.
