Old 07-04-2008, 12:37 AM   #1 (permalink)
Evil-Erik's Avatar
Evil-Erik is on a distinguished road
Default No AC or Heat
i have a 1990 tracker and the switch that controls variable speeds for the ac fan woul only wor if you moved it around just right now it won't work at all there are no blown fusesany info would help out as its my daily driver and its getting pretty hot on the drive from work
Good Times Bad Examples
1990-8 valve-3spd auto-Tracker
Evil-Erik is offline   Reply With Quote
Old 07-04-2008, 02:48 PM   #2 (permalink)
jtgh's Avatar
a/c will not do anthing with out power from the fan.
the a/c amp detects fan loss and shuts down a/c
air-conditioner-repair
the heater will not make heat with out fan air. so the heater will be dead too.
so the fan.
here is more info on the fan.
see next post.
above post shows how the fan , circuit , intererupts AC ops.
you
click me.
Old 07-04-2008, 03:04 PM   #3 (permalink)
jtgh's Avatar
Default 1990 fan circuit
here is a 1990 print
3 readings with any voltmeter , nets , answer.
start at blue wire and work up page.
when the voltage drops to zero , with fan on and blower on , bingo the fault.
in your case (above is generic)
you have 2 failures.
so the pink/black wire will NOT be at 12vdc with fan on and this is the reason
all is dead. ( this wire must be hot)
see?
unless the A/C lamp is not glowing then the fuse could be bad.
click me.
