Old 06-25-2008, 08:26 PM   #1 (permalink)
awk
awk is on a distinguished road
Default EFIE question
i have a 97 geo tracker 1.6 sohc 16v. does anyone know if i can use a EFIE on one o2 sensor, or do i need to use two EFIEs.
awk is offline   Reply With Quote
Old 06-26-2008, 01:10 PM   #2 (permalink)
jtgh's Avatar
EFIEs , that being what.
ahhh, youtube, how'd I guess that.
that's right up my alley ! Grin !
this works ! , the front oxy is the major fine tuning device. ( for some )
on many early 96 + cars this can work.
(results can very , read more)
the car starts, if the ECU enters closed loop ,the front sensor measures oxygen and thus the AFR ratio is set by this device output.
so his presention is real, and in fact I know it to work, both in theory and in practice.
the newer cars might not let you go too lean with out setting a code
and the newer cars might fail the cat performance monitors, P0421 in one case.
this is LEAN BURN technology.
of course do not get caught it is illegal.
What will happen ?( i run this technology in a foreign country , South America.
I run a car with lean burn at my winter home. gas is $8.00 , there. ouch.
I use a megasquirt custom ECU , far batter way to do this and I can run Ethanol.
bad sides:
1: the cat metals inside will be destroyed, in a few 1000 miles.
2: the above fact may clog it up. varies by car and year. greatly.
3: the above will cause P0421 (lazy cat fail) just wait a while.
4: remove it before smog check ,
5. remove it or you mech will refuse to work on your car (heavy fines for him)
on the early OBD2 cars, 96,97 or so you may not get lazy cat fail.
on 99 and newer, fur sure, because you killed the cat.
this technology is not magic it is used on every Prius , the engine runs in lean burn but has a very expensive , different technolgy CATCON that is immune to over heat.
so the answer is , this device will not do anything any useful for the rear OXY SEN.
the rear sensors is ONLY for monitoring the CAT performance.
click me.
Old 06-26-2008, 04:45 PM   #3 (permalink)
awk
you answered my question. thanks for the help.
Old 07-01-2008, 08:09 PM   #4 (permalink)
awk
bad sides:
wiring on the 02 sensor. which wires are for ecm signal. I have a black, black/white, grey, and white.thanks for the help.
Old 07-01-2008, 10:03 PM   #5 (permalink)
jtgh's Avatar
Default wires, depend, tell more... please
depends on year and if what side of connector and who made sensor.
what year car?
who change it last and what brand but...
those colors sound like Bosch side wires. see photo,as I run 100 % bosch on 3 cars.
yours sounds 4 wire.
so:
on a 95 sidekick
it is on veh. side of conn.
what colors on actual sensor varies great amounts.
vehicle harness side; 1995 eg.
yell/blu= oxy senses output to ecu-------------> you
gray/yell = special ground -----------------> you conn
blk/white = power for heater
Pink = heater enable from ECU
click me.
Old 07-01-2008, 10:18 PM   #6 (permalink)
awk
this is for a 97 tracker 16v sohc. black, black/white, grey, and white are from the engine harness side. the 02 sensor has two black and two white. im not sure what brand it is.
Old 07-02-2008, 01:49 AM   #7 (permalink)
jtgh's Avatar
red/blue = oxy output to eCU.
gray/yell= oxy out. spec. ground for sensors.
heater is.pink/blk and blk/white pair.
sensor colors are never stated on fsm prints only the harness conn side.
because they can use NGK, DENSO, or Bosch and can and do have diff. colors.
click me.
Old 07-03-2008, 10:07 PM   #8 (permalink)
awk
I GOT IT INSTALLED. WORKS GREAT. THANKS FOR THE HELP jtgh.
Old 07-27-2008, 12:39 PM   #9 (permalink)
jtgh's Avatar
your welcome. happy trails.
click me.
