Old 06-25-2008, 10:14 AM   #1 (permalink)
Default Deep Fording Cancels Ck Pos Sensor Signal?
96 1.6 16v: Anyone have real world experience w/ a stall fording rivers?
Old 06-25-2008, 04:55 PM   #2 (permalink)
Nates'90 is on a distinguished road
Cant say I have, how far in did you go?
I went to underneath the headlights, and it stayed running just fine.
Fan, alt, and w/p belt were screaming though, but it held...
http://img.photobucket.com/albums/v6...et-tracker.jpg
http://img.photobucket.com/albums/v6.../looked-ok.jpg
http://img.photobucket.com/albums/v6...gy-tracker.jpg
~Nate
Brush guard with nice lights. 235/75 r15 tires, bone stock... Better highway, no rubbing, CHEAP!!! NOW $55 each from walmart. goodyear wranglers...
I've got a good 2high 4 high 4 low transfer case for sale, 120,000 miles on it. Works great, Make offer.
~Nate
Nates'90 is offline   Reply With Quote
Old 06-26-2008, 07:47 AM   #3 (permalink)
Rhinoman's Avatar
I bent two rods fording a river . If the crank position signal is causing problems then it is most likely a bad connection. I have disconnected all of my electrical connectors, cleaned them and packed them with petroleum jelly. I use the OE plug leads (newish) and my Vit will still run with the engine underwater (I have a snorkel now).
Old 06-26-2008, 10:27 AM   #4 (permalink)
Thanks for replies. Before the next trip I wtd to gain some insight on depth others have reached. Rubber timing cover seal may keep the worst of the water out but if you stop long enough and water reaches the space betw. the trigger wheel and the sensor it seems to me it will interrupt the signal. Better to keep moving. Will put in some dielectric grease in the connector, though-hadn't thought of that. Thanks, Rinoman.
Old 06-30-2008, 05:16 AM   #5 (permalink)
p279's Avatar
p279 is on a distinguished road
I went through a very low ford. ie the water was low but the muffler was causing some steam so it got wet and the engine warning light came on presumably from spray going into something. 10 kilometres later I turned the engine off then back on and it had cancelled. Is this what you are referring to? The grease is a good idea I hadn't thought of that. I used to use an aviation grease on planes to stop water getting in but I can't remember what it is called.
Steve
p279 is offline   Reply With Quote
Old 06-30-2008, 10:22 AM   #6 (permalink)
eXpReSs's Avatar
eXpReSs is on a distinguished road
Steve
DuPont™ Krytox® ?
eX
'95 Tracker LSi, Soft Top
1.6 16v Vin6 5 Speed Auto-Hubs
HALOs and CA-40g 37mpg Hwy @70mph w/ cruise
It's all in the tune up * It's not easy being green.
Drives like a grandpa due to oil prices...
uhh and is a grandpa 18 times
eXpReSs is offline   Reply With Quote
Old 06-30-2008, 01:57 PM   #7 (permalink)
you have an obd2 car and it will be unhappy with wet wires at crank pos. sensor on the bottom and the oxygen sensors.
just ignore the P04xx errors but losing the crank pos. sensor is going to be a problem.
so seal the connector.!
100 ways to do that,
home brew thru professional.
you could just back it in silcone grease, then warp it in plastic wrap , layered with RTV.
they also sell a tape called latex rubber uncured tape, (3m?)
it is black and gushy soft, when you wrap the tape to the splice it melts into itself.
and then cures, Inside is packed in RTV by you.
this was used for 30 years before 3M started making submirsable splice kits.
(looks like tiny coffin with jello in side) used for burying cables,etc.
there are also professional Automotive connectors that seal 100% , but
are very hard to put on , with out expensive tools. but is possible.
Look at any new chevy, pop hood and look. Delphi does a geat job today.
Old 06-30-2008, 07:00 PM   #8 (permalink)
p279's Avatar
thanks for that. Is the crank pos sensor inside the cover or outside?
Steve
Old 08-25-2008, 01:12 PM   #9 (permalink)
Outside, beneath cover at base of oil pump.
Old 08-25-2008, 02:41 PM   #10 (permalink)
Default this?
crank position sensor.
that connector , must be clean.
conn. gasket good and coated with silicon grease.
if you get it water tight, it will not fail.
it can be hard to do so.
