i see what they did. its #2 (i was curious )
possibles.(no new ecu , predicate)
1-increase, fuel pressure. new pump and regulator
or modify existing via vacuum reg. (Kludge'y)
2-injector pulse width modifier box ( long for alcohol and short for gasoline) ( scaler amp)
3- run ECT SENSOR higher in ohms, (colder reading)forcing rich with ethanol.
id dont think messing with the OXYsen will solve the mismatch with hooch.(ecu limit)
Money back guarantee? no really, it is up them them to decide that, dont count on it.
IMHO.
there is one alternative (by class)
Megasquirt Stand alone ECU, has full support of Ethanol. (and many others)
cheap , easy to program (after learning it 1 time) and you can even add that
special E85 fuel detector and swap maps on the fly just like OEM new cars do.
Down side is the tuning cost. but there are some really good software tools to get close.
it can cost as low at $250 for the kit. ( i have one working)
I also know how to build the quick swap PNP cable so you can put it on the car
and swap it back in 5 minutes.
no cutting stock cables , no buying any new sensors, i measured all sensors.
You will have to abandon the MAF sensor, as that has no data tables published.
The MS2V3 has a built in MAP sensor, this will create perfect mixtures for both gas or ethanol.
just add the missing fuel density sensor , to scale the injections based on % of mix.
this Gold Box:
one last , questions, how does the system tell , if you have 1/2 a tank of E10 and E85.
E10 (standard pump gasoline)
( you need that expensive gaso line sensor to do that)
that is my idea.
I will read your whole link but it fails to have any product data sheets ,specifications, or theory of operation.
Does it work at all altitudes and temperatures? what are those limits.
facts: (review of what I see)
the guarantee does not cover, "actually making ethanol work" only that it is not hard broken causing a dead car. 30 day limit on returns (move fast)
who are they , 1 year old , they are: their web page.
where is there support page, or parts replacement page, NONE! (save 1 connector)
where is there specifications page or product data sheet.
there EPA or CARB certification for the legal modifications of smog equipment. none.
he mentions the EPA cert but the documents are not available, (I will ask EPA !)
their kit does not show how to change between TBI or MPI engines, how can that be.? He says that's YOUR problem. ( nice huh?)
there video clearly shows it is a TYPE 2 , Injector fooling device.
it takes the input fuel injection and scales it for E85
no instruction manual online to down load ( this is very suspecious to me, )
that alone would stop me dead.
power , ground, and injector (buffer box)
he is cagey, he blocks all questions on youtube, he dont like.
i asked some simple questions.
---------------------------------------their web site-------------------------
Registrant: (public data, via whois look up.
The Proof Positive Group
16446 Lafayette St
Thornton, Colorado 80602
United States
Registered through: GoDaddy.com, Inc. (
http://www.godaddy.com)
Domain Name: CHANGE2E85.COM
Created on: 15-May-07
Expires on: 15-May-09
Last Updated on: 15-May-08
Administrative Contact:
Virtue, David
davidv@theproofpositive.com
16446 Lafayette St
United States
(303) 544-9494
Technical Contact:
Virtue, David
16446 Lafayette St
United States
(303) 544-9494
Domain servers in listed order:
DNS1.PROSTORES.COM
DNS2.PROSTORES.COM
DNS3.PROSTORES.COM
