Remove blower motor case fr RHS, loosen fresh/recirc air control cables, wiring harness from blower case, discharge and recover if you have any refrigerant in system, disconnect neg batt cable, remove pass side air bag (2 phillips screws on each side are a pain to remove, esp. LH one), relay bracket, evap in/out pipes at firewall, evap case mtg nut near same, loosen/slide metal evap/heater band onto heater case, loosen evap case drain hose, air bag harness around evap case, 2 evap case upper mtg bolts, separate the case halves, remove the expansion valve, and it's miller time. Actually, better to start w/ air bag after disconnecting the battery as it will give you a bit more room. I think its a good idea to change the blower mtr resistor too while everything is apart.
