Hi, I haven't done this on a tracker, but have been around the geo engines and ran into this. I am quite certain that you would be able to switch oil pump, pan and crank gear onto the new engine and you would be fine. This is easy to do. Of course make sure your oil pump is ok and super clean if its off a failed engine. They rarely give any issues, so i would take a peak inside it and then transfer it. Good luck.
