Old 06-21-2008, 05:52 AM   #1 (permalink)
jonnybv6 is on a distinguished road
Default Spot lights on a 96 vitara 2.0 v6
Hi all, Could any one tell me how to wire spot lights into the high beam on my suzuki vitara. I have had a go but for some reason all the wires going to the main headlight are live (was all that about) Very confused Please help me if you can.
jonnybv6 is offline   Reply With Quote
Old 06-22-2008, 05:53 PM   #2 (permalink)
Rhinoman's Avatar
The lights are switched on the ground side so you need to see which of the wires goes to ground when main beam is switched on. One side of the relay coil is wired to 12V, the other side is wired to the main beam wire.
The relay contacts are wired one side to 12V though a fuse, the other side to the spots, the spots are then grounded to chassis.
Old 06-23-2008, 06:09 AM   #3 (permalink)
Hi Rhinoman, Thanks for the reply to my question about the spot lights, what did you mean by the ground side? and also the relay i have has got 4 prongs is this the correct one and also does the relay have to be ground? Thanks John
Old 06-23-2008, 08:18 AM   #4 (permalink)
Rhinoman's Avatar
ground = body/earth/0V/chassis/negative. 4 prongs is correct, the relay body doesn't have to be earthed.
Old 06-25-2008, 12:19 AM   #5 (permalink)
Nates'90 is on a distinguished road
um, why dont you just use a toggle in one of the blank dash spots to the left (or right) of the stearing wheel like everyone else???
~Nate
Brush guard with nice lights. 235/75 r15 tires, bone stock... Better highway, no rubbing, CHEAP!!! NOW $55 each from walmart. goodyear wranglers...
I've got a good 2high 4 high 4 low transfer case for sale, 120,000 miles on it. Works great, Make offer.
~Nate
Nates'90 is offline   Reply With Quote
