Old 03-04-2009, 04:37 PM   #11 (permalink)
dbacon's Avatar
dbacon is on a distinguished road
It could be the paint has been protected from fading, and now shows deeper color.
dbacon is offline   Reply With Quote
Old 03-04-2009, 05:51 PM   #12 (permalink)
deeznutts77's Avatar
Gallery: 4
Originally Posted by Bear95 View Post
I took the decals off mine and cleaned the areas. Even after cleaning, from an angle I could see the outline of the decals. I figured that the decals had been applied at the factory before the clearcoat was sprayed on. I hated the " colorful" Tracker decals and that is why I removed them. I ended up buying 3 black 4X4 decals and put them over the area where the OEM decals were.
i think this is because the paint has ware and tear, the decal "saved" the paint under it. so its shinny
Old 03-04-2009, 07:30 PM   #13 (permalink)
safest is , simple paint thinner.
will not hurt paint and desolves the glue. same for bumper stickers. too.
heat gun is best (heat shrink gun) best to remove sickers.
and will all most of the glue to go with it.....
alcohol will not work. how ever is best to clean plastic , as many solvents (most) can hurt plastic.
an the above are good to googone,etc but some can be harsh on some weaker paints.
Old 03-04-2009, 09:34 PM   #14 (permalink)
GoGeoGo is on a distinguished road
thanks jtgh. ill probably use paint thinner, for the decals/stickers, i didnt have a heat gun... but i used a hair dryer, it worked pretty well. but ill try to use paint thinner in the spring when i can actually clean my car
GoGeoGo is offline   Reply With Quote
Old 03-04-2009, 10:46 PM   #15 (permalink)
The paint is dull where the decals used to be.
Bear95 is online now   Reply With Quote
Old 03-05-2009, 11:04 PM   #16 (permalink)
1995tracker is on a distinguished road
BEFORE
AFTER:
I took em off too.... I waited for that side to be in direct Florida heat and sun as long as possible, started with a razor and it peeled right off.
And, why not, for good measure:
YES, I KNOW I need to get the front lift on,,, lol
1995tracker is offline   Reply With Quote
Old 03-06-2009, 02:19 AM   #17 (permalink)
dbacon's Avatar
Easy to tell you are havin' fun. - Stay safe!
