Old 05-14-2008, 01:35 AM   #1 (permalink)
kiradana is on a distinguished road
Default catalytic replacment
i need to know if cat is toast if it constantly rattles, every shield is tight and system tight it is on 89 tracker 1.6fi auto. as we all knowa bad cat can screwed up milage and cause engine to run bad or very rough and also stall at times. i live in canada and can get away with cutting out cat and put in a resinator is this kosher or will it screw any thing up.
kiradana is offline   Reply With Quote
Old 05-14-2008, 05:48 AM   #2 (permalink)
dmce is on a distinguished road
g'day kiranda, all the cat is there for is to convert toxic exhaust gasses into less toxic exhaust gasses.If your allowed to remove the cat do it ,if they rattle all the time they are broken internally.
dmce is offline   Reply With Quote
Old 05-14-2008, 02:34 PM   #3 (permalink)
it will rattle until it turns to dust , and when it breaks up , i can clog the muffler.
on my jeep it ,just blew down the road as dust. no ill effects.
but , here are some facts:
89 has stupid computers, on up to 91 in canada.
as car gets newer the missing cat will cause the EGR function to fail.
The EGR MOD valve must have back pressure to work (open) if it dont open
on newer cars, it will be detected by the OBD1 EGR monitor and set code 51.
when that sets the car goes to limphome mode and sucks gas like a monster
on an 89 , removing it can be ok for some people and some cars.
after 1994 , it is impossble to fool the ECU .
If it is CALif. car, mostly none can be fooled.
2 choice here. and good advice.
try a test pipe, if if MPG is ok and CEL is off and on code 51 ( you will not get 51 on a 89' so just check MPG)
if you have problems, then just take out the test pipe and put in the real Mcoy.
one can get a clone for less than $100.
this answer is for you and others with this comon problem.
Not all ECU's are the same.
Also some guys pull the cat and put in glass packs, this sets back pressure to zero
and then the fuel maps in the ECU will be ALL wrong.
car will go lean, I think?
The engine needs a certain amount of back pressure , so you dont foul up the maps.
Maps are tables in the ECU that have all air and fuel ratios for every RPM and EVERY load, they are tuned for your cars Volumetric Efficiency (the ability to pump air)
if you muck with the air pump the maps are junk.
that is the hard cold facts.
dont ask me ask any pro engine turner.
