is the lamp on at key on , no start. that is the 1st step.
if that fails replace lamp, & re-seat speedo wire plug and or ecu plug with battery term minus disconnected.
the ECU has a limphome chip, car will run fine , but it will have loss of power.
and it will burn lots of gas. as low as 15mpg.
that is the primary purpose, of this feature, called FAILSAFE by Suzuki.
Fails safe , retards the ignition timing, and also sometimes refuses to control idle.
on never cars the redundant cam and cranks sensors can fail and car will run
on all cars , many of the senors can be mimiced,
for example if a MAF fails, software tries to mimic the MAF using the TPS.
the newer the car the more of these features exist.
they want the car to still drive so you can get into the dealer shop so they can sell you something REAL expensive, see?
its a communist plot. (or oil companies some how cause this)
