hi all have just bought a vitara jlx 1.6 8v 1993 uk spec (carb) when i start it the engine idles at 2500 rpm for 2 mins until engine warms up this cannot be right can someone confirm this please also the thing dosent like to start very easily when hot it turns over a few more time then seems to be on two cylinders then three then four in the space of a few seconds i have replaced the ht leads, plugs,air filter,cap and rotor this has helped a bit. the timing was checked on a warm engine at 1000 rpm with the vacum advance attached and it was +20 deg this was then adjusted to +8 deg this is what the mechanic says this should be.
has anyone else had this problem before and can offer me any advise thanks jodyn and sally
