Old 05-03-2008, 04:03 PM   #1 (permalink)
0049ner is on a distinguished road
Default Adjusting idle on 1600 16v '97
Idle is around 500rpm and can't find adjustment to get it up to the required 800rpm. Can these engines be adjusted manually or are they ECU controlled?
0049ner is offline   Reply With Quote
Old 05-03-2008, 04:29 PM   #2 (permalink)
that's a good question.
the answer is yes and no.
yes , you set it and then after that ECU tries hard to keep it where you set it forever, there is a special procedure to follow to set it, that calls for freezing the ECU idle logic.
see your throttle body. see the top
there is rubber plug there for the idle bleed screw. ( should be there, but I dont have 97 FSM)
now the symptoms.
if idle is 500 , id suspect the IAC is stuck closed.
the acid test , pull IAC connetor , engine must speed up slow down, if not IAC is stuck.
acid test 2 ,after IAC is working, turn on all electrical loads.
A/C , Fan, headlights, defoggers, and RPM must not drop.
if it drops ,IAC is malfuntioning.
Old 05-04-2008, 02:58 AM   #3 (permalink)
Many thanks will try this out and get back to you with what happened - thanks
Old 05-06-2008, 01:35 PM   #4 (permalink)
Default Problem solved
Iac test proved OK and so adjusted idle. Idle screw on this MY is a black plastic philips screw head on top of the throttle body. Adjusted to 850rpm all working good after 3 days. thanks again
