1996 Geo Tracker transmission problems - Suzuki Forums: Suzuki Forum Site
Old 04-14-2008, 08:20 AM   #1 (permalink)
on_mitch is on a distinguished road
Default 1996 Geo Tracker transmission problems
Hi
Just found this site, I thinks it's great.
I have a 1996 Geo Tracker 2 door with a 3 speed automatic transmission.
When it’s cold it hangs in first gear.
When it’s warm it shifts smoothly, but at normal operating temperature as it approaches around 3,000 RPM it will pop out of gear.
If I let off the gas it will re-engage again.
Any ideas as to what may be the problem.
Would a fluid change help this???
Thanks in advance. Mitch
on_mitch is offline   Reply With Quote Quick reply to this message
Old 04-14-2008, 08:17 PM   #2 (permalink)
Gallery: 4
96GeoTracker is on a distinguished road
Well as for hanging in first, My Dads 97 does that and we had a 92 that done that, My 96 is fine it shifts great! But here is what he does he will go to Advance auto parts and buy a can of transmaitc and pours so much in the trans and it will shift right away for a while but as time goes on it takes longer and long until he gets some more to pour in it, From what I've found out a lot of the tracker 3 speeds are bad for this it has something to do with the shifter.
97 Geo Tracker, (Dads) 2DR,2WD,AT,PS,PB,A/C 1.6L 16 Valve
96 Geo Tracker, (Mine) 2DR,2WD,AT,PS,PB,A/C 1.6L 16 Valve
91 Geo Tracker, (Moms) 2DR,2WD 5Spd,PB 1.6L 8 Valve
94 Geo Tracker, (Parts) 2DR,4WD,AT,PS,PB,A/C 1.6L 8 Valve
96GeoTracker is offline   Reply With Quote Quick reply to this message
Old 04-14-2008, 08:29 PM   #3 (permalink)
Thanks a lot. I going to do a service on it tommorow. I drained some fluid out and put in Lucus Oils tranny fix. It really helped. The fluid is brown so I'm going to change it and the filter and see what happens. P/S I'm looking for a tranny.
Old 04-15-2008, 10:55 AM   #4 (permalink)
Gallery: 4
Good luck on finding one you can find lots of the 3spd 4WD but not the 3spd 2WD!Most of the time when you fine one they wan an arm and aleg for it!
Old 04-15-2008, 11:49 AM   #5 (permalink)
Banned
filter clogged, oil dirty.
clogged filters make the pump weak, this in turn will wreck the clutch packs and bands by making them slip like crazy.
Magic in can can NOT correct this problem.
you need to drop pan , replace filter ,and do a full power flush.
the power flush gets all the missed oil in the Fluid clutch housing. (the majority)
do that and your good to go for 50k more miles.
the master PL shows on only 2 xfr cases, 1 for 4wd and one for 2wd.
so you dont need both ,just a 3sp auto sans Xfr case.
there are other sources for this tanny, was first used on a Chevette. Long ago.
Old 04-16-2008, 09:00 AM   #6 (permalink)
Default Bandaid
Thanks for your reply
I really stay away from power flushing as it is brutal on your old seals. Pulled the pan the fluid was brown, and there was a fair bit of metal on the magnet.
Clean everything out new filter and gasket, and put it back together.
Put a quart of Lucus in it and new fluid. Still not shifting when it's cold, but it really helped the slipping and shifting problem when it warms up.
I'm going to drive for a week or so and do it again until I find a new tranny.
See what happens
Old 04-16-2008, 10:13 AM   #7 (permalink)
Banned
2 types of power flush,
external and internal.
external, as in external pump pushes oil out of engine.
internal ( or natural) we let the transmission pump out all the oil as it suck in new.
you could have a bad pump or worse
but:
failed vacuum modulor can cause ( and is external) quoting FSM page 7B17
harsh un/dn shifts
delayed upshifts
slips in L, D, R
tranny overheating
engine burning tranny fluid.
the Modulator can be checked for leak down, and for ops by applying a vacuum tool.
test diaghragm for leaks and for servo shaft full stroke with vac, applied.
there are also 3 oil pressure line tests you can do .
in low, brakes on, L gear, full throttle 5 sec max, mod vac disonnected, line pressure
161-177 psi , page 7b-4 FSM
at the very least check for oil dripping form vacuum line on mod valve when tube is dropped downward, (save $500-1000 if Mod valve is bad) 5 min check.
Old 04-16-2008, 10:17 AM   #8 (permalink)
Banned
if tranny was driven for a long time while slipping, most likely it is toast.
the damage cascades.
Old 10-05-2009, 06:28 PM   #9 (permalink)
gabednar is on a distinguished road
Default Tracker 3-spd Auto Trans Problems
I have been experiencing this cold transmission upshift delay in my 1995 Tracker. Took it to the dealer, who changed the tv cable. That did nothing. Next dealer is trying to flush the tranny to free up a sticking valve. We'll see. My question is- Does the '95 Tracker 3-spd auto tranny have a vacuum modulator, or solenoid valves, or what exactly?
gabednar is offline   Reply With Quote Quick reply to this message
Old 10-05-2009, 10:37 PM   #10 (permalink)
Banned
tv must be tested on both ends, does TB move cable proper, and
does the TV rod in tranny track TB movement.
1:1 relationship.
TV:
it can stick all the way out signaling WOT full time to tranny. bad.
the vacuum mod. is here
Slush pump diagnosis
including FSM quotes on tests.
this mod valve can stick or the diaphram leak. and you will see oil leak from vac tube.
you can have a bad Governer. on 4wd takes removing xfr case to access on car.
modulator has its own screens than can clog.
this device shifts by speed.
mod valve by motor load.
TV by throttle demand.
one can effect or kill the other. i have the color hydra maps in fsm , it is clear what can happen.
key is , does your tranny have a control issue. or real transmission fail or just loss of pressure , there is a pressure test and a stall test in the fsm
the fsm IN CAR test section is huge.
does tranny hold power in all gears ,
2nd floor it , no flare?
1st same.
no slippage?
