hi ,
its an old dog like mine,and the codes are still there.
as long as you didnt unplug battery or pull DOME lite fuse (dome = ecu memory bank)
tune up this century? (hahahahaha) no seriously.
all it takes is a reg.size paper clip.
pull the codes.
there is a huge list that can cause die.
click CEL>>>
Blinking-Lamp
click die: >>
dies
any 8valve.
battery cables terms clean and greased.
Important grounds:
top bolt on starter main big black battery wire lug , nice and tight !!!
ground strap to body behind battery. clean and tight all these.
ground at base of DIZZY
ground at Thermostat housing. all critical to ECU.
any other ground straps at fire wall to engine. look and clean them.
other killers.
if it wont restart check spark.
spark OK.
then look for injection down air horn while cranking.
this car has the easiest injector in the world (in the throttle body) just look its in full view , unlike MPI cars.
spark , or fuel,.
or the TBlelt slipped but engine is free running and you are in no danger.
Yah, mines got 51k too,
it rolled over at 100k and now it reads 51k.
3k a year, suree........... HAHAHAHA
dont forget the Cel comes on at exactly 50k ( stupid useless service switch, throw hidden switch below column on kick panel)
or pull the whole switch out it is useless and annoyiing. red cel page.
