last:
1-lube change every 2 years.
2-dont drive car with bad clutch as that can destroy the input shaft ( which are now in sort supply world wide, I just bought a new one and was informed of this fact)
3- do not loss those top rubber plugs on the tranny. if you do the lube leaks out and
good by tranny.
on 4wd, the center case is dry, on the bottom is a little vent slit.
look for it. if it is leaking only , you have a no longer dry case and you have bad seals inside (end of tranny or front of Xfr case seal s bad).
it the leak gets worse, and you skip the lube checks, the tranny will die.
same with front of tranny, if it leaks lube, fix it. (new seal) (or just keep checking lube, add as needed till eventual clutch death)
front seal , will drip on clutch and it will slip soon. so no reason to delay fix, just do it.
only #3 is unique to kicks.
on 2wd kicks the center case is wet , due to dummy transfer case.
