Parts are here and i noticed the crank pulley has a disk with six teeth on the back of the casting. When torqued, it will not turn, the teeth on the back disk are catching on the block timing mark. Otherwise the gear is identical same number of belt teeth and same diameter. Can I just cut them off? Let me know if I need to post a pic I am an early riser and did not feel like breaking out the camera this evening. the crank part number is 12630-57b01
John
