Dose any one no how much a 1995 Geo tracker 4x4 5 speed 2 door no AC weight is? and how about a 2000 chevy tracker 2 door 4x4 5 speed I was hoping to pull one of these behind my RV and would like to pull the lights one.
A quick search of online reviews for the '95 yields a curb weight of 2189. It wasn't clear if that was for the auto or manual trans, with/without AC, with/without PS, or 4wd / 2wd.
That might also include virtually no fuel or other accessories. I'd would use 2,300 lbs as a fair estimate for the soft top, 2 door tracker w/ 4x4.
I do see a lot of motor homes towing a little tracker, so there is evidence they work well for that. Note: Ensure you have followed the instructions on towing per the owners manual. friend of mine hooked up his jeep behind their motor home and forgot to take the jeep out of gear (manual trans). 200 yards later he was looking at a full replacement for the motor and trans. DOH!
MarkB.NV
1991 Tracker, 8valve 1.6L, 5 spd, 4x4, 2 door, soft-top, 103,xxx miles, w/ 2 in suspension 2 in body lift, 30x9.5/15 MT tires.
NOTE: the owners manual in my 97 Tracker says when flat towing put the transmission in 2nd gear and the transfer case in neutral.
The transfer case is whats important I dont think it matters what gear your transmission is in as long as the t-case is in N because the t-case overides the tranny. MAKE SURE THE TRANSFER CASE IS IN NEUTRAL.
I've towed Trackers with my 18000 lb RV without a supplemental brake system, but in wet weather, it can be a bit dicey. Most states require brakes on towed vehicles/trailers 2000 Lbs and above.
91 2Dr Tracker Softtop 4x4 5 Sp. 1.6 Litre 8v, Fed
Use Ubuntu Linux...It's Ready for the Desktop Now!
