connectors are just plastic blocks with pins for mating male and female harnesses to subcomponents .
be it, relays, ECU or anything and some are DLC , diagnostic logic connectors.
both of those conns, plug in to factory test equipment , (ALDL assembly line Diag Logic)
if you went to a real Suzuki or GM dealer , they would roll out the cart and plug in to these connectors, and say "everything on your car needs replacment" hahahahahah
below link explains the 3 major diagnosis connections and lamps.
Blinking-Lamp
1 hint the brakes:
if you are blowing the brake fuse one can unplug the Emergancy Light module so that it cant blow the fuse and the consentrate on fixing real brake lamps.
Brake fuse>>>> brake switch>> wires>>>> brake lamps >>> ground.
end to end path, very simple but if wires are cut or chaffed then it will blow fuses.
hint 2 .look under rear bumper for any funny trailer wiring ( non oem junk or hack jobs)
