IF B8 shorts ,the transistor then starts getting real hot.
then the ECU overloads the 12vdc power buss to the ECU , which could in fact blow the fuse to the ECU and kill car as a result. (if not the transistor roasts)
it is best to trouble shoot the electrical problems 1 at a time. starting from the most
important to the least ( only you know that ) but in this case car doesnt run, so brakes lites are useless.
I would bypass the B8/b17 wire pair. if it were mine. ( not worth the expense of blowing a 4th ECU , (count?). IMHO.
getting a new wire pair would shot gun that problem for good.
then you could concentrate on "IS my Injector good or bad ?"
0.8 ohms to 1.2ohms ( not even a tad less , than 0.8 ohms)
the nicer meters Like (Fluke , Washington grown) has low ohms range perfect for measuring low ohms.
ALSO:
some shops have an injector tester.
and all injector cleaning services have a full analysis of the injector just before the cleaning service.
they never clean a bad injector.
so one other alternative is to remove the injector and send it out for professional cleaning. (they did mine here for $20) .
then if it comes back , you know it is not shorted.
they run profiles on the injector for flow , mine had a flow of 456cc/min after cleaning. < data point , no where on earth !
my injector looks exactly like this on a scope:
http://carfix.stufftoread.com/INJECT...ors/my-TBI.JPG
notice the fancy modulation !
Your car is old, having more than one electrical problem is common.
