but, did you pinch the hose, not just hose go bad, its those other things,
mine had them ALL.
the diaphrams cracked will leak , they must be tested .
the pinch test is for those people with out the Mityvac or HF cheap version.
pinching discovers 2 faults per pinch, see?
just a simple pinch.
next is bad EGR gasket ( or leaking EGR)
then the gasket under the iAC missing or cracked.
keep an open mind about leaks,
if the RPM drops , the hose or the diaphraphm is bad.
EGR diagphram, , HIgh Idle Dashpot diagphram, , the brake booster diaphragm can leak like crazy. Pinch that huge hose and listen.
is your idle vacuum 19 inches HG.
the 16 ways of racing . (fast idle)
click>>>
racings
if all leaks are tight.
then (idle path normal)
fresh-air
the idle procedure is on the above page , i have the FSM pages I can send you. ( this is my condensed version)
you have to place a jumper and check the duty cycle on the IAC valve.
5 paths and very tricky this TBI is.
