Old 02-17-2008, 09:22 PM   #1 (permalink)
Default O-rings source for dizzy
Howdy,
I have '91 Tracker 8v with a oil leak problem - seems to be coming from the back end of the
cylinder head. I have already replace the valve cover gasket, and that helped somewhat, but
it is still leaking. It looks to be leaking oil from around the distributor.
Anyone have a ready source of o-rings for the dizzy - or is it a dealer only item?
Many thanks!
MarkB.NV
1991 Tracker, 8valve 1.6L, 5 spd, 4x4, 2 door, soft-top, 99,xxx miles, w/ 2 in suspension 2 in body lift, 30x9.5/15 MT tires.
Old 02-18-2008, 02:02 AM   #2 (permalink)
Default Use the search tool, Luke!
Ok, I promise to at least try using the search tool. I'lll just stand in the corner and fell guilty for a few minutes.
Jerry, thanks for the following post ... I take it from your post you ordered the 035 and 118 part nos for the dizzy?
Did you use the V75 prefix on both (V75-035 and V75-118) ?
Thank you!!!
hello all.
if you want o-rings that dont fail on the DISY. try these.
pn -035 (sae std numbers) disty bottom shaft.
and pn -118 , main housing to head.
prefix V75 ( Viton high temp. rings, will never fail !!!) 400 degr. rating.
50 cents each.
go to O-rings, inc, La. CA.
O-Rings, Inc. Since 1958
I contacted 50 places and these are the onlyones that have good prices and good shipping charges.
I am not affialtiated in any way, just a very happy customer and glad to get viton with out getting gouged !!!
some stores sell these for $10 each.
happy motoring.
the 118 oring is a HIGH FAILURE RATE on all KICKS 89 to 95.
any with a real distributor.
http://www.suzuki-forums.com/suzuki-...y-o-rings.html
MarkB.NV
