geo tracker,sidekick stalls,quits REPAIR
I have fixed 2 of these lately, the people said they would quit out of the blue. one came in for the fuel pump to be replaced the other was still runing,did know what to do with it cause all was well.. both had the wire harness plug behind the left rear tail light with corosion in the plug conector. It was the wire coulor pink W/black strip. just cut on both sides of plug and add 2 " of wire # 14 use heat shrink to do it right the 1st time. this wire is for the fuel pump if u here the fuel pump relay click after u turn the key on (will click then click about 4-5 second later ) but cant hear the fuel pump the maybe the wire is broke hope this helps Clayton
