89's have this samuria diode thing . i dont understand. but will lookinto
Zuwharrie.Com BBS - Index
is well known here.
any time you change load, and rpm goes nutz. id expect it to many things.
the draw is bad, i will correct it and repost it.
ITs a giant wired "OR" gate. if this or that go true, ECU is told to raise idle.
output is brown yellow to ECU.
inputs is all status of loads, HL,fan ,etc.
so what does it do?
obviosly it tells ECU to raise idle.
so , your car is working perfect. (blush) ( i will add this to my 89/90 diff page) growing.
one just needs to read the FSM ,for this (sorry dont have one, they are rare)
someone here will post the words. see it 1 time before here, someone....?
on 91 , only the A/C and P/S over load ,raises idle.
not true on 89/90
i never knew this. but is obvious.
but why.
my guess is ECU on this old buggy is too slow or the ISC just cant handle all the loads.
so unplugging it , has only 1 side effect.
idle may go below 800 rpm.
SEE ATTACHED DWG FOR DIODE GATE DETAILS.
The jpg is mod'd by me to show diode detaiis
the pdf (wrapped in zip ) is orig.
