cabs, been almost killed twice in a cab.
lima, passing on left, in intersection, against red. (last year)
Manila , fell asleep , almost went off cliff, I grabbed wheel , saved all on board.
(sorry, flash backs)
the pump:
it has to pump. ok.
fit (hole) and not leak.
have the correct pressure for full throttle op's. (under sized?)
reach bottom of the larger tanks on some kicks. it is deeper.
have the same ohmic range as the origional or the fuel guage will not work.
if it is over capacity , it will be working really hard and die soon.
Because the regulator is holding 30psi, and the unit is designed for 50. Bad idea that would be.
rating on 8v is diff. than 16v.
put in a pinch......
