gee, unplug TCM, then plug it back, breaking dirt barrier and it works.
then
unplug TPS , and then back, same theory.
this fixed one guys here, just last week, no parts at all.
look at wires and contacts for breaks and contamination.
always eyeball it first.
you did read Page 9 of that manual called 1994 transmission diagnosis.pdf , right. called testing the transmission in manual.
if tranny shift perfect and doesnt slip , tranny is good.
if this is true, then it is an electrical problem.
33 is most likely the bad part.
I could walk you thru testing the TPS, to prove it is in fact bad.
you choice.
