This is the problem: I graduated from the world of 1972 GMC pickup and a !965 Volvo, both with carburetors and single point ignition, to the world of electronic eveything with no catching up in the middle. If someone would take the time to post a list of all the commonly used abbreviations such as ECM and ECR, etc., it would be much appreciated by this farmboy mechanic.
ABS - Anti-lock Brake System
CPU - Central Processing Unit
CTS - Coolant Temperature Sensor
DIS - Distributerless Ignition System , Direct Ignition System
DTC - Diagnostic Trouble Codes
ECU - Electronic Control Unit
EEPROM- Electronically Erasable Programmable Read Only Memory
EFI - Electronic Fuel Injection
EGR- Exhaust Gas Recirculation
EPROM - Erasable Programmable Read Only Memory
ESC - Electronic Spark Control
EST - Electronic Spark Timing
HOS - Heated Oxygen Sensor
IAC - Idle Air Control
KAM - Keep Alive Memory means that the ECM is powered while ignition key is off, allowing the computer to retain RAM
MAF - Mass Air Flow
MAP - Manifold Absolute Pressure
MAT - Manifold Air Temperature
MIL - Malfunction Indicator Lamp
MPFI - Multi Port Fuel Injection
OBD - On Board Diagnostics
OBD II - A government imposed requirement to standardize OBD systems
PFI - Port Fuel Injection
PROM - Programmable Read Only Memory
RAM - Random Access Memory
RWAL - Rear Wheel Anti Lock
ROM - Read Only Memory
SEFI - Sequential Electronic Fuel Injection
SES - Service Engine Soon light
SFI - Sequential Fuel Injection
SMPFI - Sequential Multi Port Fuel Injection
TPS - Throttle position Sensor
VSS - Vehical Speed Sensor
WSS - Wheel Speed Sensor
Thanks Ranger88den and Schoner. I put the list on file and added a printed copy to my growing reference notebook. At sixty-five years old I hope I have enough years left to learn some of this stuff. I probably should start saving my money and find a good honest well-trained mechanic. I've been reading all the posts in the Sidekick section of this forum and this list will definitely make it more understandable.
Cool. I've been to Port Angeles a few times; nice town. I go hiking or camping on the peninsula at least twice a year, and that usually involves driving through Port Angeles.
Just thought of two more that I've come across on various forums:
FSM - Factory Service Manual
PO - Previous Owner
