Old 02-01-2008, 02:02 AM   #1 (permalink)
Kathrein is on a distinguished road
Question Vibration noise Vitara when driving
Hi,
16v JLX (RH drive)
I've just started getting a vibration when driving. It starts at about 30mph and gets worse the faster I go.
It happens when I'm in 2 wheel drive high, I don't think it is wheel balance as the vibration is not coming up through the steering column.
I've manual wheel hubs and they both in the free position.
The vibration disappears when I freewheel (dip the clutch) and gets worse when I drive uphill.
The vibration slightly decreases when I take my foot off accelerator at speed.
However the vibration gets worse when approaching stalling (eg say I stay in 4th gear and I take my foot off the accelerator a let the car slow down.)
I don't know if this is related but at very slow speed (eg parking) when I turn full lock I have a point where the steering goes heavy past this point the steering is free/easy again.
This vibration is major and nothing like loose exhaust, trim, tyre pressure etc.
CV joint?
Transmission fluid level? (cant find dipstick)
I'm a fair way from a dealership and would like opinions before I set off.
Thanks Kathrein
Kathrein is offline   Reply With Quote
Old 02-01-2008, 06:59 AM   #2 (permalink)
Default Rear Wheel drive
Hi again,
spot the mistake?
my son has taken a look and its REAR wheel drive when its in 2 wheel drive high.
So the CV joints won't be the problem he guesses.
He has twisted and pulled on the prop shaft and cant find any play.
The wheel bearings all around the car have checked (jacked up and rocked) and the VERY VERY VERY slight play is the same all round.
BTW the car is SWBase.
Thanks in anticipation
Kathrein
Old 02-01-2008, 08:57 AM   #3 (permalink)
Good diagnostic checking so far, I'm no expert, but here's a couple of ideas. BTW how many km/miles on the truck? It does sound suspiciously like a bad u joint to me. I have seen ujoints over the years which appeared under quick checks were ok, but were in fact worn out. If it goes away when you disengage the clutch, that pretty much rules out wheel
balance issues, and also, I would think, anything from the transfer case on down to the front wheels. Unless there is an engine issue causing it to run rough and vibrate, and transmit this vibration down the driveline, my vote is for a rear driveline issue. Good luck and keep us posted, those of us with 15yr old + track/kicks could encounter stuff like this anytime!
Old 02-01-2008, 10:39 AM   #4 (permalink)
Post Main dealer diagnosed --Rear shaft assy prop --
Hi,
The vitara is a 1996 model. (78k miles)
I've just got back from the main dealer who took it for a test drive and has diagnosed the prop shaft as the most probable cause.
Unfortunatly on their system it give two conflicting part numbers
27102-60A10 -- 16 -- @ £165.51
or
27102-85C00 -- 25 -- @ £172.06
Both shaft prop assy prices plus vat plus fitting.
They estimate about an hours labour cost.
Apparantly they have different diameters across the four cylindrical ends of the yoke. Parts guy did me a nice drawing.
Are the ubolts the same thing as the yoke?
Anyone got a good source within the UK and would we need special tools to fit, apparantly the fitting is very straight forward.
Anyone got an idea how to measure the ends (or other way of identifing) without removing the old one?
One final question what breaks or wears out on a prop shaft to need it to be replaced? Obviously it must be out of balance to cause the vibration and I'm certain it has not been hit bumped or damaged as the car is only used on the road.
Again thanks in anticipation.
Regards
Kathrein
Old 02-01-2008, 11:32 AM   #5 (permalink)
aquanaut20's Avatar
Hi K,
You will probably find, once you drop the prop shaft that one on the universal jounts is rusted and frozen in position, it is not required that you replace the shaft, just the Xjoints in the ends, this can be accomplished with a large bench vice, here in Canada the joints cost about $15.00ea
This might help with the proceedure,
DIY: Replacing Universal Joints
92 Ford Explorer, 450k
97 Ford Explorer, 360k
99 Tracker, 4dr, 4x4, 2L DOHC, auto 165k
Old 02-01-2008, 11:48 AM   #6 (permalink)
Question Thanks --- UK supplier needed
Hi
thanks for the advice and information, very much appreachiated.
Anyone know of a good UK supplier / mail order for the universal joints?
It looks fairly straight forward, but I bet something will get in the way of a quick fix.
~Bye the way on one of the web sites I see lots of photos showing the removal and replacement process.
On one of the photos there appears to be a grease nipple?
I won't be able to get my son to check if there is a grease nipple on my cars prop shaft.
~Do you think it is worth checking and greasing first?
All replies really appreachiated.
Regards
Kathrein.
Old 02-01-2008, 02:08 PM   #7 (permalink)
Hi Kathrein, I'm unsure if you refer to a grease fitting on the u-joint, or on the actual drive shaft. Some u-joints have grease fittings, others are "greaseless" . In any event, greasing a shot u-joint isn't going to work. Once they wear out, it's too late, and they need replacing. If there is a fitting on the driveshaft tube, that would be a slider joint, and yes, by all means grease it, but again, only as maintenance, it's not going to fix anything. As regards changing out the u-joints, the procedure described is accurate, however this is only when all goes well. My experience with u-jts. has been that when it comes to u-joints, it almost never "all goes well". They come apart easy when new, but as time and mileage go on, they get harder to get apart. They can be very frustrating, and if one isn't careful, you can easily "spring" a yoke, sort of stretching it open wider than it is supposed to be, and then you are done. Then it's off to a driveline repair shop to get a new yoke put on. My humble opinion (I'm sure there will be others who disagree)
is that it's best just to get a mechanic to do it. That way he can fight with it, and save you tons of frustration, bleeding knuckles, and extra trips to the parts store (or worse).
I hope this helps.
Ken
Old 02-01-2008, 04:40 PM   #8 (permalink)
aquanaut20's Avatar
Suzuki Club UK - Fitting U-Joints
These guys are in the UK, maybe they can steer you in the right direction.
Old 02-02-2008, 05:39 AM   #9 (permalink)
Thumbs up Thanks
Thanks for reading and for the advice.
Hope some of the information in this thread will be of help to others as well.
Its a weekend here so cant get much done.
Regards
Kathrein
