Schematiic
SEE 94 MPI SCHEMATIC.
this should put you and the correct path.
ECU pulls in , fuel pump relay.
make sure this relay is energized and not bad.
this relay is below ECU , you can see wire colors.
one can hot wire the relay and run the pump from this location, no pull tank.
could be wires, the relay, the pump.
i think? you are blowing the fuse with the black /white wire.
this line runs many things, not just the fuel pump.
FP draws about 5 amps normal.
merry christmas.
