Thanks PR for helping with the green light. I was hoping it had something to do with my other problem. I recently replaced my Speedo cluster. Before I did the back up lights stayed on. After the change out they stayed out. I thought it might be the switch. Changed it out. Lights still don't work and when put the car in reverse the 4WD drive light comes up on dash. Checked to see if back up lights come on when in 4WD. No lights. Anybody shed some light on this?(no pun intended). Is there any where on line I can get a wiring diagram?
wow!! I'll check on the schematics, but meanwhile, if you still have the old cluster try to replace it back if those symptoms stop. You have a A/T or manual?
Thanks Guys- Car is '96 Tracker 2 Dr 4WD. Manual Transmission. I did try and put it in 4WD to see if the back up lights go on. No change.
PR- thought about putting in the old cluster but that is my last resort! I had to tear half the dash apart to get it out. I changed the cable as well. I think I would need to disconnect the cable fron the trans and get slack to get it out. Maybe take the steering wheel off again. I hope someone can help with schematics to exhaust all avenues before I do that.
