Old 12-14-2007, 03:31 PM   #1 (permalink)
jags is on a distinguished road
Default help please vatara jlx fatboy 93
hi all hope you can help. i have a vatara dakara jlx fatboy 1993 .been running great untill today.i started it up left it running for 5 mins to warm up .as its cold thought i would get the heater warmed up first when i got in and set off it stalledwell i thought i stalled it .turned her over but it wouldnt start so pushed it in the garage.a guy said it could be the fuel pump or relay or fuse .any advice on this modal as to were the relay is and pump fuse .or better still were is the fuel pump situated .looked under the boot carpet but no access point.my cars stuck and iam stuck help please thanks jags
jags is offline   Reply With Quote
Old 12-15-2007, 01:16 AM   #2 (permalink)
all cars same;
spark or fuel , compression
I presume it cranks hot and fast.
did you hold down pedal to fool and use the secret unflood mode.
if this works car was flooded.
sense it is far easier to add fuel then spark.
we flip that double headed coin to Fuel.
spray 1 second some "instant start spray can" or some propane in to the induciton.
propane 3 second snort (not ignited OK?)
if car goes VEERRROOM and tops, you lost fuel.
if car startes stumbles and smokes it was rich.
if car does nothing repeat only 1 more time.
if car will not show life with a little extra fuel then it has lost spark or the timing belt fell off or is loose.
alternately as a step one procedure , insert a test spark plug on then end of one of the spark plug wires and crank and look.
if no spark then skip all the above.
that should get you on track.
