the whole deal
actually its Kerchoffs law of series circuits, "the same"
"Kirchoff's laws. First, the current in a series circuit is the same throughout the circuit."
LAB 3
so either post will produce the same number.
but removing the NEG lead is safer.
how to measure Ghost Currents: (start on high amps and work low!)
Back to Batteries and Charging:
battery is 38 amp/hr battery , any 38 or larger will work so long is it fits and doesnt hit
hood ,which is easy to do on kick (boom battery explodes)
that 38 could be higher if 4 doors, or what every you are driving , you didnt say.
your alternator spec:
55amps
will have a high charge voltage at lower temperatures (sitting and not hot)
14.5 up to 15.3vdc (fsm) (2000 rpm test point)
your battery will have only 50% capacity at that -25C ambient temperture.
any cheap volt meter will work. even the real cheap needle kind.
IS YOUR DASH CHARGE LIGHT ON WHILE RUNNING? Symbol of a battery.
next we have that pesky battery,
the voltage of any lead acid battery will tell you the state of charge at rest, engine
not running , chargers removed and resting for 4 hours.
that magic voltage is :
12.65v for lead acid plain jane all numbers below are 100% State of Charge.
12.80v for a calcium lead acid "freedom battery"
those two numbers are at room temp.
for you they are:
12.5v at -18C Jane
12.66v " " freedom <<<< this should be your car. magic number.
any charged battery that reads below 12v has a shorted cell, chuck it.
with these numbers you have everything you need to diagnose your charge circuit
down to almost -20C.
Meters: any autostore, Ace hardware, Harbor Freight(no Canada) $2.00 or radio shack.
they go for $15 max at many places and every mech should have one.
get a battery warmer and a block heater.
the trick on Kicks is a LOW + Fat, low height battery in cold climates.
