very sick car: 16v (code 12 ok)
"Dosent matter if the TPS is plugged in or not warm or cold it does the same."
good clue: Tps is easy to test on or off car, leave on. check ohms thru whole throttle range ( 0 to 3k ohms 3-5k at upper end)
forget #4 injector !
You sound lean to me , even cold , that is a problem!
#3 is just the weakest cyclinder and is sensative to lean more than the others. maybe?
Vacuum hoses,
pinch them one at a time, (closest to manifold) and if any cause a change in RPM, suspect that circuit.
exceptions: PCV , no pinch, ISC idel valve air tube, do not pinch. and fuel reg.
check brake booster hose must not leak or cause RPM change.
if the one you are doing (EVAP) then pinch it too, you can keep it pinched to drive.
same for EGR vac hose, pinch it , listen and drive like that.
the one hose I have this is not pinchable is the diaphragm in the idle TB shaft.
i call it a dash pot (16v have this?) it can increase idle under certain conditions.
make sure its diapharam is not leaking but sucking its tube with lips (yuk) or a vac test tool. ( i think you dont have this part)
disconnecting either the TPS or MAF will cause ecu to mimic the missing part.
it is my opinion that, that action will cause rich mixture.
I think that if pulling both will kill engine ,try it? (if it doesnt kill it then car will be richer)
{love to know what happens with that ?}
if it runs that means ECU is using the MAP sensor that manual says is never used. hummm
if by doing THAT, engine power does not improve then it must be spark.
It is true , that trouble shooting cold running , will fix this car easier and quicker.
Keep in mind, in a shop with no 4/5 gas analyser connected to oxy port , we would:
that fancy tester will give an instant answer to mix.
ALT:
1- bleed in more air to see what happens.?
2- or bleed in some propane gas to see what happens.
if more air helps, engine is rich.
if propane helps, car is lean.
the brake booster hose is a great air source. (dont just pull it off, as it will kill engine)
one pulls it , plugs hole (engine side) and then opens it up gradually, noting the effect.
if non of these tricks help the problem , then spark is bad.
your car has a fuel rail, on that rail is a plug that must be pulled and and adpator installed to measure rail pressure. its non trivial to do.
tests 1, 3 and 6 are critical to you:
bomba
you need 30 psi of pressure ! the FPR must be tested.
i am not sure if your problems is A/F or spark.
Clues: (kick commons)
compresson above 150psi? and equal ( will be low if Tbelt slipped)
ignition timing close to 8 deg BTDC when looked at first time, if it was way off and you changed it then that too is a clue to TBelt slip. IGN timing should NOT drift off with usage. ( ECU has timing freeze jumper to see correct static timing)
is crank pulley 17m bolt tight, 94fl/lbs torque and pulley not loose as is comon?
94 is new TSB spec.
IGN timing will bounce even with Time Freeze jumper in place. ( if pulley is loose)
( sorry we are at rich lean , spark still) but here are my Shade tree tricks.
