1992 sidekick jx missing bracket for sensor - Page 47 - Suzuki Forums: Suzuki Forum Site
Old 05-21-2009, 01:49 AM   #461 (permalink)
Banned
hi victoria,
yes,still lurking. and at midnight.
if you need xfr case parts i have them
and a used drive shaft or 2 is sure be be lurking around here too.
good luck with u-joints.
its a classical style.
when removed from transfer case all the lube inside runs out.
so drain xfr case first.
welcome back too !
jerry
Originally Posted by star2525 View Post
Hi guys! Still haven't replaced the Oil Pan seal, monitoring it still, I have a new scenario and need help, Rear Drive shaft, am replacing the front and rear joints to the Rear Drive shaft, I got the joints and my friend that is replacing them says he would like to see a picture of diagram of the 4 wheel drive transfer case that goes on the transmission, he says on Chevys they are chain type and want to know what he is getting into on the Suzuki, he mentioned he may have to replace the Yoke but doesn't know yet until he tears into it, he says I have about 1/2 inch of play, and I am hearing what I thought was an exhaust leak, isn't, it has to do with the joints and this yoke thing, so I am hoping someone has pictures of how this all goes together onto the transmission. Any pertinent information would be greatly appreciated. Thank you.
Victoria
Old 05-21-2009, 05:32 AM   #462 (permalink)
ranger88den's Avatar
My j-10 jeep w/Dana 20 was chain driven but my 95 Tracker FSM says gears. See attachments and good luck.
ranger88den is online now   Reply With Quote Quick reply to this message
Old 05-21-2009, 08:40 AM   #463 (permalink)
tusong200's Avatar
Gallery: 3
tusong200 is on a distinguished road
Wow!! 462 posts (now463) for a missing bracket. Very Kool, and tons of info.....
tusong200 is offline   Reply With Quote Quick reply to this message
Old 05-06-2010, 12:51 AM   #464 (permalink)
star2525's Avatar
star2525 is on a distinguished road
Default 1992 Suzuki Side Kick JX 1.6 16 Valve Engine
Hi All!
It's been a While, I still have the Beast. Did the Rear and still have the Front and Oil Pan Gasket yet to do, been checking it frequently.
I have a New Issue I'm hoping someone can help me find the answer to, I have a New Holland Skid Steer Loader that the Control Panel Board needs to be worked over or tested and refurbished. A New Board is almost 700 dollars, so I'm hoping someone can help me with this Issue. It won't stay running, and if the board is replaced it stays running, I had a Loaner Board for testing it, so know that is the Issue. It reminds me alot of the Computer for the Side Kick, am hoping you guys can Steer me in the right direction on this one.
Victoria
1992 Suzuki Sidekick JX, 1.6 16 valve engine 4 door, 4 x 4, automatic 4 speed with overdrive
star2525 is offline   Reply With Quote Quick reply to this message
Old 05-06-2010, 01:43 AM   #465 (permalink)
BOZO's Avatar
Gallery: 3
BOZO is on a distinguished road
Hi, Victoria. Kick-fix highly recommends the services of David Ruberg Technical Services for ECU repairs. Maybe they could take a look at your board.
BOZO is offline   Reply With Quote Quick reply to this message
Old 05-06-2010, 11:50 AM   #466 (permalink)
Banned
Hi Victoria and welcome back( yes i changed my handle ,and i retired, no more midnights.)
4 ways.
1: look for damage ,correct it and pray.
2: buy new or refurb, board.
3: have tech fix it , in circuit ( using the real thing connected so he can see what is going on)
4: send your board in to maker and have them fix it.
if you had a schematic of the card, that would allow any tech to fix it.
PS , the post was long because she had many veh problems and they clashed. ( she worked very hard to solve them)
Old 05-06-2010, 02:46 PM   #467 (permalink)
star2525's Avatar
Thumbs up 1992 Suzuki Side Kick JX 1.6 16 Valve Engine
Hi Jerry,
I'll look for a Schematic, if I find that can you take a look at it? You definately did a good job on my Side Kick Computer when you had it.
They guy that took it off said there was green on part of the board at one side toward the bottom, and my husband had removed the door from it a long time ago, so possibly water damage to that one area could have contributed to this.
I have a Manual for it, I'll locate that and see if there is anything in it, figure that is going to be the first place to start.
Victoria
Old 05-06-2010, 04:52 PM   #468 (permalink)
star2525's Avatar
So far I've found the Operators Manual with a Trouble Shooting Section that has Fold Out Wiring Diagrams, the actual piece is called an Electronic Instrument Cluster. I'm trying to corelate the Wiring Diagrams with the EIC to see if that is it. Plus I'm doing searches for the EIC.
Victoria
Old 05-09-2010, 06:12 PM   #469 (permalink)
star2525's Avatar
Hi Guys,
I called New Holland in Canada and they had me contact someone about 50 miles away that said they would send me a copy of what they have, don't know yet if that is what I already have in this Operators Manual or not yet, its supposed to be in the Mail, so will know more when I get it.
I did do a google search for New Holland Electronic Repair and found a few pages that came up, one was from someone named Farmtronics, so think I'm going to try and call that tomorrow to see if I can find out anything promising. From the first page of the search I did it looked like a good one to start with. In one of their pictures on their site, the board looks alot like what was in their picture. Any other suggestions would be greatly appreciated.
I still have a Seal Kit to get for the Hydraulics pump and hope that is all it needs with that repair and not the pump being totally rebuilt. Locally here Muskingum Tractor priced the pump seal kit to me for 500, the place in Columbus 50 miles away priced the same pump kit for 70 some dollars and said there is only the one pump. So I'm finding quite a varience in pricing.
Victoria
