not knowing the country , makes this hard, but here goes. (diff places ,diff names)
front and rear , ratio must be the same (at risk of stating obvious , blush)
FSM and EPC do not say ratio's. Enter the hacking zone.....
on each car
raise 1 rear wheel, put car in neutral.
put chauk mark on Diff front pinion flange. and off ground tire.
as you turn pinion, count pinion turns it takes to make 1 full turn on tire.
compare car 1 with car 2. if same , ok. if not back to the bone yards.
other then pulling the members and counting teeth .?
the people that know this, are on another forum. the ZUK rock crawlers all have a list for
gears.
google, sidekick rock crawlers.
PS: EPC SHOWS (92 range)
DIFF gear sets, on year, and MT and AT , there are some match up on 94/95 given same tranny.
