be care ful , this could get expensive.
lost spark.
1- COP , "coil on plugs" x4 , most likely not them.
2- igniter module (what the cops plug into ) , may be bad.
3 -ecu bad. ( last choice but possible.)
4 - CAS dead. (cam angle sensor )
5- Power problem to any of the above. (connections, fuses,relays)
first check CAS, with out cas signals there will not be spark or injection.
a scan tool can be plugged in and you can look for codes .
It may say , no CAS. signals. via DTC code.
