it would be difficult
3 pins, Ground, +12vdc and Signal out.
signal out is an open collector transistor and NEver sources current (it sinks it only)
so the DIZZY would have to short 12, to the sig out. ( not likely)
Shconer is correct, all 92 will suffer 1 ECU fail. The "Rubicon" junk caps in side leak.
You can get yours fixed for $70 on EBAY.
His statement was speculation. (unless he tested the input ports of the ECU)
see link on this page , $70
ECU
the more expensive EBAY service have longer warantee and some will ship first and THEN you can ship yours back (less down time) . Lots of choices here.
cheaper than a tune up, we are blessed.
Full spec I made on dizzy.
http://carfix.stufftoread.com/IGN_ti...IZ-CAS1W86.jpg
