94 Tracker firing order? - Suzuki Forums: Suzuki Forum Site
Old 10-17-2007, 04:01 PM   #1 (permalink)
leica is on a distinguished road
Exclamation 94 Tracker firing order?
Help! I just replaced the tune up parts on my 94 Tracker 8 valve. Apparently, I screwed up the firing order. Anyone have a schematic of the firing order? Thanks.
leica is offline   Reply With Quote Quick reply to this message
Old 10-17-2007, 04:17 PM   #2 (permalink)
Shconer's Avatar
Shconer is offline   Reply With Quote Quick reply to this message
Old 10-17-2007, 04:34 PM   #3 (permalink)
Ok, I know the firing order now, but the distributer is cockeyed and has no numbers on it so I have no clue what the correct order on the cap is even by looking at the diagram.....Also, is it bad to turn over the motor with the incorrect order? I don't want to mess anything up.
Old 10-17-2007, 04:47 PM   #4 (permalink)
Shconer's Avatar
Use the two cap mounting screws as a referance. It's the first one to the right of the bottom screw. It's not really bad to turn over the motor with the incorent timming but it might back fire. You have to make sure that #1 piston is at TDC.
Old 10-17-2007, 04:56 PM   #5 (permalink)
Banned
dizzy
SEE PHOTO OF DIZZY,
Old 10-17-2007, 04:58 PM   #6 (permalink)
OK, so actually the TOP screw looking at the distributor itself, #1 would be to the left? I'm confused. Also, how do I get #1 to TDC and how can I tell it's there?
Sorry, but I've never had this much trouble before, I feel like a dumbass.
[edit]
So looking at the dizzy, the position of the rotor there tells me I'm at TDC? Is it OK to turn over the motor with the ignition until I get at the right position, or sould I do it by hand?
Old 10-17-2007, 05:19 PM   #7 (permalink)
Shconer's Avatar
Yea its fine to turn the engine over with the starter up it's better to do it by hand to get it right on. 17mm. On the 16v the fan blades are not spaced all the same, theres a space that is bigger so you can get your habd in there.
Old 10-17-2007, 05:33 PM   #8 (permalink)
Hmmm, I don't think I have a big enough wrench to turn it.....All I have is a 3/8 socket 17mm, and my 3/8 wrench is kinda small. If I remove all the plugs will it be easier to turn?
And how will I be sure I have it right on TDC? Can I just watch for the piston to come up through the plug hole?
Old 10-17-2007, 05:40 PM   #9 (permalink)
Shconer's Avatar
Yes you can watch the piston thru the spark plug hole and yes it will be easier to turn with the plugs out. I usually stick something inthe spark plug hole like a peice of wire or srink wrap or something so you can see when its at TDC. The 16v crankshaft bolt is 17mm as I remember.
Old 10-17-2007, 05:44 PM   #10 (permalink)
I have an 8v if that makes any difference. Anyway, my battery is dead now from cranking it over constantly....Great way to end the day.
Security Question
