index
click Link above, then on "I think my ECU is dead". take the test. its easy.
you have spark but now injection.
it is bad ECU or weak pump.
try the ECU test first ( you dont need to run fuel all over heck, at least YET).
ask questions.
your car is a 1.6L TBI (throttle body fuel injection)
cool it is cuz you can look down bore while cranking and see NO GAS flowing (use a mirror ).
wear asbestos suit, I mean teflon.
yes, there is a relay called the Fuel Pump Relay.
but listen in the gas cap hole for fuel pump buzz.
FP only runs for 3 seconds each KEY ON , no start.
get help, you listen , someone keys ON.
