I've seen it done on Trackers here in Florida. They can be taken off, it's just a pain in the ass. Unless there is some sort of kit floating around, I'm assuming you have to fabricate something to make it easier like the Samurais. I wish I had a welder, I'd give it a shot.....Maybe it's possible to weld Samurai hinges on Tracker doors, who knows.
The doors can be removed by splitting the hinges. There are two types of hinge, one type has a rivetted pin and the other type has a circlip. If you have the rivetted type then you can replace them with the circlip type. The pins can de difficult to remove first time because they have a spline and the paint gets in the way too. Once you get them out give them a good clean and its easy from then on. Be careful when knocking out the pins as the hinges are easily bent.
OMG! I'm going outside to start working on this right now. I'll get pics.
I started cutting down some stock doors to make 1/2 doors. I wasn't happy with the way the first one turned out and haven't done the second yet. Its surprising how much lighter the doors are with the glass and upper framework removed.
