as above check all fuse, underhood and under dash.
listen for FP startup at gas fill neck. ( you already did that)
Before anything make sure MAIN relay is pulling IN.
If main doesnt pull then many things go dead, most important is spark, by killing the CAS.
I have FSU car schematic 96 , looking.
shows FP , grounded on right.
and then going to a FPR ,says Behind Center of WP (W is blurry)?
needs main relay closed 12v to FPR coil. shows Main next to FPR. ( kind of , actually but not next to)
then ECU pulls in FPR relay.
next:
looking at EPC (parts list photos)
see bracket with 4 prongs under dash right side of radio.
shows 4 relays , top being FPR , PL Part id #5 , PN>38850-50F50 , PN changed in 97.
good way to find is make the buzzer , buzz, keyin, doors open, and find buzzer.
look behind it. bingo (I am looking at exploded view to say that)
happy kicks
