back to square one:
95 VITARA?/ not in the USA, that started in 1999.
so you are in a NON USA country. (oops) ? Are you In the USA?
if not then we must guess which of the 28 variant Vitara's world wide , you may have.
worst case: ( like someone moved a car from Russia to Germany ,etc)
your smog sticker? (white under hood) has one of these numbers. what is your code?
E01, E03, E22,E24,E28,E33,E60,E63 ( i think that means target country Emission code)
my guess:
there you go, it is lean. ( at least on transistions)
I take it , you can cruise down the freeway at 60mph all day and not issues.! just a Throttle tansition issue, correct?
NO MAF sensor. ( scratch that) "Speed Density System."
here is a list , by order of cost:
* vacuum leak ( this engine races with any air leak , scratch that !)
* Oxygen sensor ( over 100k miles replace i,t on suspesion)
* TPS ( easy to test on car or off)
* Weak Fuel PUMP (low pressure all the time) ( possible)
* MAP sensor. < I dont think this is it.
TPS: ( un plug TPS, and check against this list with ohm meter)
http://hodson.myftp.org/TPS-data.GIF
when turning throttle the TAP or wiper armoutput; it must not JUMP, it must be smooth and proportional. It's just a very expensive Variable resistor.
when I test it I do:
end to end resistance. 3.5-6.5 k ohms 3500-6500.
Note the idle stop must be defeated with vacuum.
I have read that the TPS is the primary ,off idle detection device for the ECU (not the MAP) , it is said to give you a boost of gas , until better map readings are obtained. ( in the software)
I say all this on the presumption that You DO NOT HAVE A CEL lamp glowing during IDLE or DRIVING! <<<< ??
AND that the lamp glows at KEY ON, no start ??
if the LAMP never glows, (after checking for bad lamp) then the ECU is bad.
ECU
I hope this nfo proves helpful.
PS: if everone would fill out there profile. that would greatly help.
country, year, model, engine size # of cylinders, tranny type, 4wd/2wd, number of doors.
eg: USA 1.6L x4 8Vlave, Sidekick, 5sp, 4wd,2door
