98 JX Auto Trans problem
Have a 98 Sidekick JX 2dr, 4WD with auto trans (mech calls it a 180?) Started getting genereic data code of P0740 indicating some problem with torque convertor final gear mechanical lock at about 53 mph. Car only has about 50,000 miles with about 12,000 being towed miles. Knowledgeable friend suggested a full flush as a precautionary measure. Cleared problem code for a couple of day but it came back. Secondary indication was that after sitting for extended period, after starting, trans would not be responsive for a few minutes, then fine. Mechanic suggested Torque Convertor may be leaking down when sitting suggesting leaky seal on center shaft. I did check suggested by him and found dipstick level 4" higher than normal after sitting which seems to support his theory.
Has anyone run into this problem and could a leaky center seal be responsible for my problem with high speed lock down of Torque Convertor as suggested by chronic P0740 code?
Any inputs appreciated.
Joe
