Just picked up my "new" Zuki, 1998 2dr 5sp manual and I have a question or three...
1-The clutch engages real low, meaning that I have to press the pedal ALL THE WAY TO THE FLOOR and it will start grabbing within the first two inches of the floor (or so).
I'm not sure what this means, if the clutch is simply brand new or if there's a problem somewhere else that might eventually prevent me from disingaging the clutch EVEN when pressing the pedal all the way.
I know a worn out clutch will only engage at the TOP of the pedal, NOT the bottom like in my case.
The clutch otherwise grabs fine and is nice and solid, gears are normal too.
2-They replaced the front brakes, discs and pads, but not the rear, the inspection reads 20% left. The handbrake is really high but that's an easy adjustment, only thing I find is that when I brake it feels like I need to apply a lot of pressure to obtain breakage. Is it possible the brakes weren't adjusted properly and only the front brakes are working?
Or is it more likely there might be a brake booster problem?
3-I can hear a vibration at around 2500RPM from the bottom of the engine compartment, towards the front, sounds like a bearing.
I need to open the hood and listen to it more attentively under daylight. I picked up the truck after 8PM and it was dusk...
4-The truck otherwise looks and runs great, to be honest, if it weren't for the 140.000kms on it, it would look like it just rolled off the assembly plant! It's not in great condition, it's in SHOWROOM condition!!!
I'm so happy with it this far I had tears of joy in my eyes when I drove of with it!!!
