Old 04-28-2007, 02:56 PM   #1 (permalink)
bboyfrost_7 is on a distinguished road
Default 1996 sidekick compatibility
hello every i am ben "
i just bought a 1996 suzuki sidekick jx and it needs a computer what other computers other than the obvious (sidekick 1996 4 dr manual tranny) one can i use to get it running like for example can i use one from a 1994 at all if not. why and what is the difference.
bboyfrost_7 is offline   Reply With Quote
Old 04-28-2007, 05:13 PM   #2 (permalink)
is there any help on this one?
Old 04-28-2007, 06:06 PM   #3 (permalink)
I don't have any help, only to let you know people are out here. I think 1996 started OBD II which I believe is different from earlier years and probably different computers. I'm pretty sure they(ECMs) vary between different engines and drive trains. Good luck, Dave
Old 04-29-2007, 03:58 PM   #4 (permalink)
so if i get a 96 to 99 sidekick 4dr manual tranny computer it will work?
Old 04-29-2007, 04:33 PM   #5 (permalink)
Shconer's Avatar
Yea that should work. I wouldn't try anything older than a OBDII 96. There are differences one of them is the OBDII engines had a crankcase position sensor in additon to the camshaft positon sensor.
Old 04-29-2007, 05:47 PM   #6 (permalink)
ok what computer could i use then 96 to 99 5 speed computer for 1.6 ltr also does it matter if it is a four door or two door it comes out of. as well does it matter if it from an auto or manual tranny truck
Old 05-05-2007, 10:46 PM   #7 (permalink)
hey just wondering anybody can give me info for this
i need to know if i can use a ecm out of another vehicle?
does it matter auto to standard (my car is standard)
does it matter if the ecm was from a 4x4 or no? i have 4x4
does it matter if the ecm is out of two door? i have a 4 door
i would like to know asap because i want to start driving this so i can start transfering it into what i want it to be!
also wondering what is the biggest tires i can put with about 1.5 coil spacer lift? i don't want to rub at all!
Old 05-06-2007, 07:59 AM   #8 (permalink)
I don't have any info, however, you might check with a junkyard, as I think they have books that cross reference part compatibility. Good luck, Dave
