5) Install cylinder head to block.
After applying oil to cylinder head bolts, tighten them gradually
as follows.
(1)Tighten all bolts to 53 N.m (5.3 kg-m, 38.5 lb-ft) according to
numerical order in figure.
(2)In the same manner as in (1), tighten them to 84 N.m
(8.4 kg-m, 61.0 lb-ft).
(3) Loosen all bolts until tightening torque is reduced to 0 in reverse
order of tightening.
(4)In the same manner as in (1), tighten them to 53 N.m
(5.3 kg-m, 38.5 lb-ft).
(5) In the same manner as in (1) again, tighten them to specified
torque.
Tightening Torque
(a): 105 N.m (10.5 kg-m, 76.0 lb-ft)
(b): 11 N.m (1.1 kg-m, 7.5 lb-ft)
NOTE:
Don’t forget to install (b) bolts as shown in figure.
6) Install water outlet cap.
7) Check timing mark on crankshaft as shown in figure.
This was taken from SQ416 manual from
www.suzukinfo.com
