Old 03-28-2007, 10:21 PM   #1 (permalink)
sidekick101 is on a distinguished road
Default Timing, Timing, Timing!!??
I need some help. This is frustrating. Some of you may remember my last post. Well after I picked the truck up from the mechanic I reset the timing to 5 degrees and all was well. It ran great for about a week. Then I got the same symptoms as before. I checked the timing once more and it was off again. I don't what's up with that. I never had this problem until recently. I tried to set the timing back to 5 degrees and it didn't work. I had to set to 16 degrees for it to run. I kept trying to stall and had no power. The timing as it sits is off the scale. If there were a scale it would be like 80 degrees.
It's a 93 sidekick 16v. I just spent $400 on a computer that I didn't need. I can't get my money back. I have no codes. I have checked the timing belt and marks before and it's right on. I need some help. Any ideas. Could it be the CMP in the disty?
This is what I have to do for it to run and no I don't drive it like this.
You want to here something funny. When I got out to turn the disy I left the ignition on with the door open. I turned the disty completely counter clockwise and then back and it sounded like it shorted out something. When I did it my door chime stopped chiming for about a second and then started again. It did it every single time. It sounded almost like the battery cable was disconnected and reconnected because I could here all the relays click. Is this normal or do I have a short somewhere?
sidekick101 is offline   Reply With Quote
Old 03-28-2007, 11:53 PM   #2 (permalink)
tracka96's Avatar
No doubt you have what I and a few others have had. The crankshaft gear (that drives the timing belt) wears where the key in the crank slot holds it on. The key also wears, really bad, and the groove in the crank wears. On mine I had to set the timing to about 18 degrees till I found the trouble. I'll look around and see if I still have the pic of the worn parts. I wouldn't drive it anymore till you find out if this is the trouble, might let loose all together. Tracka
tracka96 is offline   Reply With Quote
Old 03-29-2007, 03:36 PM   #3 (permalink)
See that's the thing. Remember in the last post I told you that my crankshaft pulley wobbles. I wobbles more now. I thought it was just the pulley.
Old 03-29-2007, 04:08 PM   #4 (permalink)
adoubleo is on a distinguished road
sorry about your worries, i had the same issue for a short while then i purchased a new pulley and key as the old onbe was eaten up like termites on wood.
i shall take a pic and you shall see.
remove the crank pulley and evaluate them.
Allan.
adoubleo is offline   Reply With Quote
Old 03-29-2007, 04:33 PM   #5 (permalink)
Allan.
Is this something I can only get from the dealer. Yes pics will help.
WES
Old 03-29-2007, 04:55 PM   #6 (permalink)
you can get it from a dealer but i got mine from a salvage yard for 20.00 and a bunch of other stuff too
Allan.
Old 03-29-2007, 06:39 PM   #7 (permalink)
volfan4's Avatar
volfan4 is on a distinguished road
will the pulley off an 8 valve motor work? I am parting one out and will sell cheap(labor involved) plus shipping.
volfan4 is offline   Reply With Quote
Old 03-29-2007, 06:51 PM   #8 (permalink)
Allan.
Sounds like a good idea but they are hard to find around here.
And I don't know if the 8v would work.
WES
Old 03-29-2007, 07:42 PM   #9 (permalink)
it should work, mine came from a 16v and my car is an 8v. just compare the groove and pulley grooves for the belts.
Allan.
Old 03-29-2007, 08:16 PM   #10 (permalink)
What part of Nashville do you live in? I live in Whitehouse.
WES
