Old 03-09-2007, 08:23 AM   #1 (permalink)
mazz68 is on a distinguished road
Question oil in air intake
I have a 97 vitara (sidekick) no emmisions model 1.6 automatic
I keep gettting oil in my airintake tube it leaks all the way down to the filter i keep having to add oil anyone have any ideas as to what may be causing this? thanks
mazz68 is offline   Reply With Quote
Old 03-09-2007, 12:40 PM   #2 (permalink)
Shconer's Avatar
Im not sure what you mean my "no emissions" but it sounds like you might have excessive crankcase pressure and it's blowing oil through the crankcase breather on the valve cover.
Old 03-09-2007, 01:49 PM   #3 (permalink)
suzuguy's Avatar
suzuguy is on a distinguished road
you got a pcv valve still hooked up?
suzuguy is offline   Reply With Quote
Old 03-10-2007, 06:30 AM   #4 (permalink)
I just changed the pcv valve and the IAC valve. What do you think might be causing the excessive crankcase pressure?
Old 03-10-2007, 05:09 PM   #5 (permalink)
Shconer's Avatar
Bad piston rings.
Old 03-13-2007, 09:39 AM   #6 (permalink)
do you think its still the piston rings if i am not burning oil? there is no smoke out of the exhaust.
Old 03-13-2007, 11:51 AM   #7 (permalink)
adoubleo is on a distinguished road
question?
is there a tapping/clanking noise in the engine??
Allan.
adoubleo is offline   Reply With Quote
Old 03-13-2007, 02:34 PM   #8 (permalink)
Shconer's Avatar
A compression test will give you a pretty good idea how wel the rings are sealing. It is possiable that the rings are leaking just enough to pressure up the crankcase but not enoguh to smoke.
Old 03-14-2007, 06:56 AM   #9 (permalink)
yes there is a slight tapping
Old 03-15-2007, 04:39 PM   #10 (permalink)
i had a 93 pathfinder that had the rings all broken thus the tapping, you may need to check ther compressin and then replace the rings.
Allan
