No Power, Service Engine Light
Just after a snowstorm yesterday, I was driving the 96 Sidekick 1.8L when it began too lose power significantly. The 'service engine soon'' light came on and the truck began to backfire and shudder. Took it to a questionable garage and they said it was a misfire on cylinder number 3. They indicated that there was a fair bit of moisture down around the coil / plug on cylinder numder three. He said it could probably use a 'coil boot' but in lieu of that, he dried it up and used dielectic grease (new plugs too). His fix improved the situation for about a half hour and now the problem is back although this time, no engine light. The mechanic himself did not seem convinced that his fix would really cure the problem either. My guess is the coil itself on that cylinder...
Does anyone have any advice or suggestions before I bring this thing into my regular mechanic? Thanks!
