Old 01-19-2007, 02:03 PM   #1 (permalink)
tman is on a distinguished road
Default RPM'S Question
Going 65 mph my 91 (1.6l) sidekick rpm is at 4000 and at 75mph is at 4500 and about 80mph it is at 4800, is this normal or is something wrong? Please help!!!!
tman is offline   Reply With Quote
Old 01-19-2007, 03:11 PM   #2 (permalink)
It's all about final the drive gear ratio. Sounds like you've got high 4's 0R 5 to (something) gearing. It's a lot of work to correct by adding lower ratio differential gearing. I'm assuming that your ride is a little low on horsepower from the factory, thus the high ratio gears to compensate. You COULD go with taller tires. That will lower the RPM at speed, but also throw off your speedometer and worsen acceleration at the same time. Speaking of such...are you sure that your speedo and tach are accurate now?!?
I run 3000 rpm at 70 MPH in my Zuki FWIW.
Click for pics
Old 01-19-2007, 03:47 PM   #3 (permalink)
tracka96's Avatar
What transmission do you haave? Tracka
tracka96 is offline   Reply With Quote
Old 01-19-2007, 05:17 PM   #4 (permalink)
Shconer's Avatar
MAX your Suzuki is a 1999 probably has different ratios. 4000PRM at 120KM/H sounds normal for either the 5 speed manual or 4 speed automatic.
Old 01-19-2007, 05:21 PM   #5 (permalink)
I'm with ya'! Just trying to help sort out that Lil' Sidekick issue.
He's probably got a higher RPM to engine power ratio than what I'm running to help compensate for his smaller engine. Either that, some significant "off road" gearing (factory OR modified).
Click for pics
Old 01-19-2007, 05:38 PM   #6 (permalink)
tracka96's Avatar
If it's a 3 speed automatic I was wondering about the touque converter clutch lockup. Tracka
Old 01-19-2007, 05:39 PM   #7 (permalink)
Good point!
Or maybe he's not out of low range! (if he even HAS the capability. Don't know)
Click for pics
Old 01-20-2007, 10:46 PM   #8 (permalink)
My sidekick has a 5 speed manual, and it was bought from a owner in Wyoming so it could have been modified. Also after i rewired the plug to the injecter to get it running, (plug on harness was broke) now it smokes a little bit. Smells a little like fuel smell,so by useing starting fluid in it a couple of times, could i of fouled out the spark plugs? Or could it be something else? Thanks for the help!!!!
Old 01-21-2007, 12:42 PM   #9 (permalink)
My 1995 Tracker, 1.6, 16v, 3 spd auto runs @ 3700 rpm @ 65 mph. Seems high compared to my 96 Sunfire w/4spd auto, but w/o overdrive I guess it's to be expected. Good luck, Dave
